Building Design Suite 2013 compatibility with AutoCad Revit Suite 2013 software
1 REPLY 1
debbdes8
372 Views, 1 Reply
Our office is currently running Autodesk AutoCad/Revit 2013 software. Our other consultants are currently using the Building Design Suite Ultimate 2013.  Are the 2 software packages (Building Design Suite 2013 Ultimate and the Revit Architecture 2013 package (AutoCad 2013 and Revit 2013)  fully compatible?
thanks.
1 REPLY 1
scott_d_davis
in reply to: debbdes8
yes, they are the same builds of Revit.  The difference will be this:  the Suites versions of Revit have all the Arch. MEP, and structural tools.  the Autocad Revit Suite will only have the Architectural tools.   But, yes, they are compatible.
Additionally, your office should have been automatically cross-graded to the Building Design Suite, so you should have that available as well.
Scott D Davis
Sr AEC Technical Specialist
