Hi all,
I’ve been struggling to find a way to create a drawing list in Revit that automatically shows the revision submission for every sheet. See the image below as an example. At the moment, we do this “manually” by turning on a simple Yes/No parameter – triggering the display of the black dot in the drawing list. I would like to populate this information automatically based on the revision information already attached to each sheet.
Any guidance would be appreciated.
A short while ago there was a whole discussion about this kind of issues.
See the thread Sheet Indexes and Revision Schedules - Why are they disconnected?
Maybe that will help you along, but basically it is a manual process.See the thre
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for the link to that thread. Yes. I have implemented a similar solution. It is still manual - but manageable. I was hoping I was missing some key point that would make it work automatically.
Does anyone know if Dynamo could help automate this task? I posted a similar question to the Dynamo forum.
