Browser organization - duplicated “all” Project Browser Sort Group issue.
4 REPLIES 4
KamikonLK
434 Views, 4 Replies
After use „Transfer Project Standards” I have duplicated “all” Project Browser Sort Group.
The "delete" button is inactive .
Is it possible to delete duplicated “alle” Project Browser Sort Group?
4 REPLIES 4
LisaDrago
in reply to: KamikonLK
Try this...
Set another to be current (so that the alle is unchecked)
select the word alle without checking the check box and see if the delete will be active.
Image attached for reference...
The all is default and cannot be deleted.
When I did a transfer project standards it did not bring the all in a second time.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
KamikonLK
in reply to: LisaDrago
 Unfortunately delete button is still inactive.
"Alle" is project borwser sort group "All" default form German template.
 Is it possible to transfer project standards without bring "alle" sort group?
LisaDrago
I am sorry - I did not know that was German Smiley Embarassed
So I am thinking... I do not think it (transfer project standards) would create a duplicate (2 alle) - so if the alle already existed - it would not recreate it...
In the images - I see all and alle - so it is bringing it over, during the transfer you are not able to specify which ones it brings.
And I am thinking it would still see it as a default it will not delete it. So I do not think you can delete it.
I am hoping someone else may have a better resolution for this..
LD
KamikonLK
I found a similar issue in this post:
http://forums.augi.com/showthread.php?142200-Delete-Project-Browser-Types
But no answer.
It seems that, transfer project standards duplicate "all" sorting group regardless of the language, unfortunately without  possibility to remove it in future.
