This is our 1st project on Revit, so i'm looking for any useful suggestion
on project setup.
I would like to add the following categories:
construction document views
working views
(within the above categories, I'm guessing I should have both new and demo
views)
consultant backgrounds
Where do you create the new categories? In Browser organization? How do you
assign the views to a category?
Thanks for your help.
"Scott Davis" wrote in message
news:5416753@discussion.autodesk.com...
you make new "folders" by creating/assigning new categories, and filtering
by those categories. How would you like to organize it, and I'll try and
help you out.
"Nancy" wrote in message
news:5416511@discussion.autodesk.com...
How do you create a new folder within the Browser window? It was mentioned
at AU to create a folder for working views so that you can keep a separate
folder to hold the same views that have the visibility set correctly for
the sheets that no one would work in. I've looked at settings/browser
organization but that won't let you create folders in the browser, it just
lets you display the browser differently.
