Yes try pinning it. Shortcut is PP, UP for unpin. It's like AutoCAD's
locking command but it works for objects not layers.
"Jay" wrote in message
news:5426712@discussion.autodesk.com...
When working in a plan, I can accidentally select a section, even though the
section line is broken so that it doesn't actually continue through the
plan. This is getting rather frustrating as it is easy to move/copy/delete
the section without knowing it until later on I find that my sections are
all messed up. Is there any way to prevent this other than turning the
visibility off while working?
