Brickwork renders incorrectly around window openings.
4 REPLIES 4
alive3d
467 Views, 4 Replies
Incorrect brick pattern renders around window openings, refer attached.
4 REPLIES 4
vector2
in reply to: alive3d
That would be in your Texture Editor dialog.
alive3d
in reply to: vector2
Thanks for your reply.
The pattern appears correctly on the wall face but incorrectly around the sides of the window opening. The texture editor does not allow separate editing of these two surfaces.
vector2
Just duplicate that wall brick and call it "window opening brick".
It's like a different material, (actually it is a different material),
that has a different position for the same bricks. So with the
duplicate, only change that position. And you need to "paint"
that window opening brick where you want it.
alive3d
Thanks again. I have never used the paint function!
I remember on the early realases of Revit, this issue never used to be a problem.
I appreciate your help.
