Come to my Au class this year and I'll show you. Basically just edit the structure of your brick wall, switch the preview to section, click modify and unlock the masonry layer, air space, and any other layers you want to continue down into your brick ledge. then say ok, now you'll see a base extension, type 1'-4" then in section click join geometry. Select the brick wall then the foundation.
