I am looking for a way to vary brick coursing in a model to create openings between bricks (see attached). I have tried using a brick wall with an array of openings in it but it seems that there should be an easier way to accomplish this????? I don't want to use sweeps and/ or reveals since they are continuous down the length of the wall....unless I am missing something? Isn't there a way to change the surface pattern of the brick coursing (i.e. the size of the bricks) and if so is the direction to go?
Thankx
