I have two different masonry walls, one is CMU and Brick, the other is metal studs with brick masony. Both walls use the same brick and color, etc. The brick and metl stud wall renders tin the representation it should. The brick and block renders a completely different color. In addition when I click the rendering visual style, the brick and block wall becomes transparent. I have looked at everything. Any suggestions?
