Brick at 1/16"
2 REPLIES 2
tcupp
181 Views, 2 Replies
Brick at 1/16"
I have some brick walls in a model that will not show up when the model is plotted at or below 1/16" scale. It is almost as if Revit simplifies the print because the brick would be so small at this scale.
Is there anyway to over ride this and force it to show up?
I am using the default Revit brick material.
Images attached.
2 REPLIES 2
tcupp
in reply to: tcupp
I finally figured it out...I just need to print with raster graphics on.
dat_lien9764
in reply to: tcupp
I have tried plotting using the "Raster Processing" but my brick pattern still shows up as a simple shade. Could you tell me the steps you took to get this to work?
Thanks!
