break line mask region in Revit 2013
7 REPLIES 7
Message 1 of 8
Barryfisher
4086 Views, 7 Replies
Hi I have some sections and am using the break line with a masked region but in Revit 2013 the masked region only works in the Wireframe Graphics display option. It does not work in the Hidden Line display. It was fine in 2012
Any thoughts
Cheers Barry
7 REPLIES 7
Message 2 of 8
LisaDrago
in reply to: Barryfisher
I have attached 2 images - break - Hid - that is the break component in hidden line mode and the second - BReak - WF is wire frame. It appears opposite of what you are experiencing.
Can you post some images?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 8
Barryfisher
in reply to: LisaDrago
Images attached...
Cheers Barry
Message 4 of 8
LisaDrago
Can you post an image with the break component highlighted?
See Below
LD
Message 5 of 8
Barryfisher
Attached
Message 6 of 8
LisaDrago
Nothing jumping out as to why it is reacting this way...
Is it only in one file or others?
LD
Message 7 of 8
Barryfisher
It is only in this project. I started the project in 2012 and upgraded to 2013 but we have other project that we have done the same to an have no problems.
We have 2 break line, the standard that works only in Wireframe and then our company standard break line that we normally use. This works in all other projects but does not work at all in this project in either wireframe or hidden.
Cheers Barry
Message 8 of 8
rosskirby
It could be a filter or a visibility/graphics override that's causing the problem.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
