I have a rectangle (looks like a label border) showing up in my room tag. It's a simple tag taken from the OOTB room tag family. I'v re-edited the family, checked the parameters and values. All label borders are off, but this one looks like its either part of a separate, invisible label or a separate rectangle that I can't find to delete.
Any ideas?
TIA
Solved by CoreyDaun. Go to Solution.
The typical cause for this is that the Annotation Categories are turned off in general in the Family, so you can't see the rectangle. Open the Family back up, go to the Annotation Categories tab in Visibility/Graphics Overrides, and make sure that the 'master' is marked as 'on'. You should be able to see that pesky rectangle now.
Thank you much
I had a chance to try your fix and it worked perfectly.
My projects looks a lot cleaner now.
many thanks
