Solved by Robertc62. Go to Solution.
Thank you so much! I have been trying to get a straight, usable answer on this for ages now
Several years later, and this is still a very useful post. Thank you @Robertc62!
Thanks for this! Apparently this is the most difficult pattern in the world to find! Haha, thanks for posting it. If anyone who finds this wants to change the spacing of the battens, just change the numbers as shown (use notepad to edit the .pat file) in the attached screen shot. In this case I've just doubled the original 12" spacing to 24". It can be whatever you want.
Lifesaver! Thank you! I've been looking for that file example everywhere.
Thanks for the file! This is super helpful, @Robertc62 .
I am using this answer more than a decade later, and turbosquid has evolved since then. It seems to only hold 3D models now and Revit Families. Is there another website that has a library of .pat files for users to download?
Dear Lisa Drago,
Only recently did I finally get to access PyRevit.
I can tell you that the day you install PyRevit, is the day you say goodbye to accessing or making (,.pat) files from the web.
The means to create your own any kind of hatch pattern lies within PyRevit for free and it is super easy to make surface patterns . no more 1s and 0s, no syntax no lines of strings of numbers, just draw whatever you intend and with a couple of clicks PyRevit turns that into a model pattern or a drafting pattern for you and adds it to your project file and you can save them out.
It is a revelation for (.pat) file creation and access and the people who made it and made it free deserve the biggest thanks and mega hand claps.
