Blue Circles in Linked Struct Model
4 REPLIES 4
644 Views, 4 Replies
I've got a structural model linked into my arch model. There are blue circles appearing over all of the columns in the struct model. They can't see it on their end. When I turn off their columns in Visibility Graphics, the circles disappear so it's something connected with the columns. Does anyone know how I can turn the blue circles off?
Attached is a PDF showing a circle. It's blue in Revit but black in the PDF.
Any tips are appreciated!
4 REPLIES 4
this is the analytical model you are seeing. you need to turn off the analytical lines subcategory under the structural section of object styles.
I went to Settings menu/Object Styles, and there wasn't a special Structural section or tab. I looked under the Model Objects tab>Structural Columns and I didn't see Analytical Lines, either. Can you please point me in the right direction? Is this something I should be doing in the consultant's model? Thanks for your input.
Also make sure to check the "show all disciplines" checkbox in the
Visibility Graphics, or you wont see the Analytical Lines categroy.
wrote in message news:5825835@discussion.autodesk.com...
That was the missing step. It worked - thanks to you both!
