look at any shaded line view of a building with red brick...
notice all the black lines INCLUDING the brick pattern lines..
also notice if you change to shaded view only- all the
black lines go away INCLUDING the brick pattern lines..
i want a shaded view WITH the brick pattern lines..
and changing the brick pattern line color is
easy.. the pattern lines seem to be a separate function from the edge lines anyway and yet they go on and off with
all the edge lines.. i was able to use the linework tool to make
the edge lines invisible one by one but that took forever..
lines are in the visability graphics dialog but i can't
get it to do anything that way..
i want a shaded view with pattern lines.. thanks
