Somewhat new to Revit and was wondering if someone could please tell me how to get the dashed lines in the bifold door? Thank you vry much.
Dallas
Solved by julianjameson8403. Go to Solution.
Solved by aghis_no. Go to Solution.
Don't forget that you can also add a sub-category of lines in the door category specifically for the dashed lines and assign linetypes and colours to that sub-category. When you draw your symbolic lines you just change the line sub-category in the properties palette
