Bifold Door
5 REPLIES 5
dylanyoungmandolin
1206 Views, 5 Replies
Bifold Door
Somewhat new to Revit and was wondering if someone could please tell me how to get the dashed lines in the bifold door? Thank you vry much.
Dallas
5 REPLIES 5
You have to edit the family and draw them.
1. Edit the family
2.
Option a: in the plan view, just draw lines representing the folded doors, using symbolic lines (symbolic lines will be visible only in the view they are drawn). Of course you will have to deal with locking the geometry to the reference planes... and categorizing the lines you draw as "swing lines".
option b: create a separate family for the "swing" and nest it in the original door family and control its visibility. this second option depends on the way
regards
Don't forget that you can also add a sub-category of lines in the door category specifically for the dashed lines and assign linetypes and colours to that sub-category. When you draw your symbolic lines you just change the line sub-category in the properties palette
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
Thank you very much, awesome!
Thank you very much aghis.
Thanks Julian
