Lets say I wish to create a bracket to use on a roof (in this case, to attach a solar panel to the roof). Do I create a new project (ie, "solar panel bracket"), save it, then import it. OR Do I create it within my building project under an existing "family", by copying an existing component, and renaming/modifying it somehow?
Thanks!
Solved by Alfredo_Medina. Go to Solution.
The two options that you have mentioned, are in other words, these two alternatives, in the same order:
1) Create a new family, in the family editor.
2) Create an in-place solid.
The most recommended option is the first one, because:
