I may be misunderstanding but looking at the image, just use the wall tool.. on the contextual ribbon with the drawing tools... use the arc...
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
