Best Practice: Slabs / Floors
4 REPLIES 4
trevorpan
2708 Views, 4 Replies
My goal is to model a slab and underlayments so that any section, represents good linework-rather than change it in each view. It is Revit, right?
I've created a typical floor slab in a cold climate. 4" concrete, vapor barrier, 2" insulation, 4" abc, subgrade. Under Visibility/Graphics you can control some lines, but I have found it impossible to bold the slab and have hatches, lines below be thin lines.
So, for a view specific section I can change this with linework.  However, if I create another floor type to have the concrete "thick lines" and underlayments "thin lines" the vv overides all of them!
Suggestions?
Trevor Pan
Trevor Pan
http://www.trevorpan.com
4 REPLIES 4
hi,
there is a better method but also per View.
In your Section View : Properties > Visibilty / Graphics Overrides > Edit > Model Categories > Override Host Layers - check Cut Line Styles >Edit > Host Layer Line Styles - make changes here as you want for entities that contan layers......The settings are only for this  View , but you can resolve this problem by using View Templates   in your Template File...
Constantin Stroescu
trevorpan
in reply to: trevorpan
Constantin,
Thank you very much.
While it seems to have solved the bottom line, for some reason the rigid insulation shows at lineweight 2 (a guess).  But it is thicker.
Any ideas on this?
Trevor
Trevor Pan
Try these steps:
  1. In Host Layer Line Styles there is a note which I underlined in red....
  2. following the underlined from 1 - : Manage > Object Styles > Model Objects > Floor - expand (+) > Common Edges - make changes for Line Width - Cut
step1
step 2
Constantin Stroescu
You are a distinguished mentor.
Trevor Pan
