This is fine and good, adn with filtering I imiagine it could feel pretty powerful, but in principle, until there is a general notes category, or you can control sub-categories, it will always feel like a workaround. I can't believe they're on teh 13th version, is it, and still haven't figured out how to deal with text.
Yes, you can edit your document in word, save as PDF, then save the PDF as a .tiff (or .tif), then insert that in paper space of your AutoCAD document.
At my work, we have a Word document, which we edit. When it is ready, we make that a PDF and then an image. We link the image in Revit. However, I am hoping to find a better way.
That is a very bad workflow.
Develop the notes in Revit, using a Legend, Schedule, Note Block or just Text.
Hello.
Creating a Key Schedule based on Internal Point Loads totally solved my problem.
I now have a Key Schedule called Floor Plan General Notes that I can edit, place on multiple sheets and split into columns.
Thank you so much.
Michael
