what output are you expecting?
black? - use default black lines
color? - change to color lines and be sure to always print color to a color
printer.
"I see an option for black lines, grayscale & color. If you use black
lines, what happens if you attach color to a wall"
if the lines are color on the screen and the 'black lines' print option is
used the lines will print black (halftones will not print correctly either)
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
wrote in message news:5612282@discussion.autodesk.com...
Does everything have to be drawn in black? With AutoCAD you could create
CTB files, which doesn't appear to be an option in Revit. So if I change my
walls to appear purple or something, they are going to print purple,
correct? Same for door, windows, etc..?
I see an option for black lines, grayscale & color. If you use black lines,
what happens if you attach color to a wall?
Anyone have any pointers, for getting started?
