Revit Architecture
aalonsojaver
Message 1 of 5 (811 Views)
Beams and Columns with finish material
811 Views, 4 Replies
08-31-2012 01:36 PM
What can I do if I want to add some finish material to a column or beam????
1. i tried with Paint comand but it doesn´t work.
2. For a beam its only work if I add a architectural column? and in case of beam what can I do?
3. I have to edit my family?
Thanks !!!!
Product Support
Chris.Aquino
Message 2 of 5 (768 Views)
Re: Beams and Columns with finish material
09-05-2012 10:57 AM in reply to: aalonsojaver
You should be able to change the finish material by modifying the Material under Materials and Finishes in the Properties Palette.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
aalonsojaver
Message 3 of 5 (761 Views)
09-05-2012 12:50 PM in reply to: aalonsojaver
Thanks for the answer
I did not explain myself
I want to have two differents materials in one column or beam: the material for the structure, example Concrete, and a finish material, like paint.
I need something like the material of the wall where you can add some layers to one wall.
Product Support
Chris.Aquino
Message 4 of 5 (722 Views)
09-10-2012 12:51 PM in reply to: aalonsojaver
Thank you for the update.
The only way we have found to do what you are trying to do, would be to add the layer manually in the family.
We understand that this may not be the preferred workflow, but we have not found a better way.
Chris Aquino
The Revit Clinic
@Revitclinic
aalonsojaver
Message 5 of 5 (717 Views)
09-10-2012 01:20 PM in reply to: aalonsojaver
Okey, Thank you !
