Because you may want to see a layer of stucco on top of the concrete when
cutting the elements.
I'm interested. how do you do this? For a column would you make a family
that contains a tube (concrete) inside another tube (stucco)?
"JTB" wrote in message
news:5519075@discussion.autodesk.com...
You mean a beam or column with layers as a wall? No, you have to make a
family for that.
But, why don't you just assign a stucco2 material which will render as
stucco but when cut, you see a concrete pattern.
