Beam Roof
3 REPLIES 3
GHASEM_ARIYANI
526 Views, 3 Replies
Beam Roof
Hi
I created roof like the image below:
But I've spent a lot of time، Because Every one of them alongside each other with different angles got adjusted.
How can I set the parameter,In the line set them to control irregular shape,Instead one by one can adjust.
Revit File and Family Attached is.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
3 REPLIES 3
I suggest you to use Beam System :
  1. make first an In Place Mass
  2. then builld beams on the top of it using 3 d snaping
  3. at last, use Beam System - with the option 3d checked
Constantin Stroescu
BIM Manager AGD
I added a few screenshots to make it more clear:
  1. Create an In Place Mass - use for this two vertical named paralel Reference Planes. Then , draw a rectangle shape on one of them and an upper curved shape on the other ...Select the two shapes and then :Create Form -ok.... the form is something like in Image 1
  2. In project > Structure > Beam > with 3 d snaping checked , Pick Lines - result four beams in closed shape - Image 2 and Image 3
  3. Structure > Beam System - from Properties check Constraints > 3d and Pattern >set Layout rule (to control the distance between beams) and Beam Type .  From Modify/ Create Beam System Boundary > Draw > Boundary Line > click Pick Supports and click on the beams created in step 2 - Image 4 ..Take care of Beam Direction to be oriented corectly...
  4. The result will be something like in Image 5
Constantin Stroescu
BIM Manager AGD
Hi
Thank you Constantin
Because of you answered my questions with patience.
Rail Community
