Hi
I created roof like the image below:
But I've spent a lot of time، Because Every one of them alongside each other with different angles got adjusted.
How can I set the parameter,In the line set them to control irregular shape,Instead one by one can adjust.
Revit File and Family Attached is.
Solved by constantin.stroescu. Go to Solution.
I suggest you to use Beam System :
I added a few screenshots to make it more clear:
Hi
Thank you Constantin
Because of you answered my questions with patience.
