Beam not showing up Cut Pattern
3 REPLIES 3
neelamgupta7633
881 Views, 3 Replies
This is quite weird because revit architecture 2013 is showing this error. In order to see beam in my architectural layout, we are changing the cut plane value in the view range. With this step I can see the beam but not the cut pattern of the beam..very weird.
Also, one more thing, just to check I copy pasted beam modeled in revit 2011 in revit 2013 and I could see the cut pattern. So is something wrong with 2013 beam revit family?
3 REPLIES 3
DaveDrahn
in reply to: neelamgupta7633
Make sure you view's detail level is set to medium or fine
neelamgupta7633
in reply to: DaveDrahn
I have checked my view's detail level during that time. Still facing the
same issue.
Thanks.
Neelam Gupta
i have the same problem !! any one knows what to do?
