See attachment.
I can't figure out why the bas is visible through the floor :s while the middel part is not. The part where you can see the color of the stairs is cut out of the floor.
Did anyone had similar problems?
Alex
Hi JBH,
View range doesnt change it.... It never was a problem before and I didnt change anything about the view range.
How can I associate the stairs with a level other than make the base start on a certain level?
Tab only switches between the whole stairs and the railing... What I ment with 'base of the stairs' was just the lower part (as you can see in the attachment in my original post).
Other suggestions :(?
Thanks anyway
This should be it. Seems normal right?
(Apart from it not being useful hahaha... but dont mind that its not important)
Hey, been a while 🙂
I attached a file where it occures. (To make the level work I made 2 stairs and hid a different one on the two levels).
It worked when I made the number of threads equal to the amount that was needed, but it never was a problem in previous files.
See what you can find or else its probably a glitch somewhere!
Thanks in advance mayne!
http://www.wetransfer.com/downloads/ba75ce0799d9c99f973d85d61b68e85a20130118133112/3c4bcb8cbe36cce99...
