I created a baluster panel from Revit's library of family templates - the baluster panel template. I had no issues, warnings, etc. while making the family and everything looked as I wanted. However, I loaded the baluster panel into my project and for some reason the panel is broken looking. I have uploaded the rfa file and a screen shot of what I am talking about. Please help. Thank you.
I found many issues in your baluster family. Any of which will cause and issue when you try to use it in your project. The overall concept is a nice one but I would be reluctant about using such a complex system. Many voids in Revit are generally not a good idea. Mixing this with a baluster family is simply going to compound the issue. I'm not sure if you created this from scratch but the Back and Front Reference Planes (when looking in Left View) do not control the overall length of the panel. If you open the out of the box Baluster Panel 1. rfa in Railings > Balusters and look at the Left view, you will notice that moving the Back an Front Reference Planes have a direct effect on the panel. It will either get longer of shorter depending on what was you are moving.
I suggest starting over with the aboved mention out of the box family and only making one changes at a time, then load into project, make sure it works, then and only then moving on to the next change. I hope this helps and let me know if you have any follow up questions or comments.
Thanks for posting.
I understand what you are saying. However, how do you suggest I would achieve such and intricate pattern? It needs to be made to look exactly like the manufacturer's product.
We cannot train on the application but one suggestion would be to use a solid panel and call out the pattern/how you want it built in 2D Detail Views. Given how complex the pattern is, if you do model it, you may run into performance issues. Revit is good at many things but cutting thousands of little holes is not recommended practice. Beyond that I'm not sure what else I can offer.
