What you are seeing is called "Moire" patterning, and is typical when rendering
something with very small repeatable patterns (e.g., brick).
Perhaps the instructions here can help:
http://en.wiki.mcneel.com/default.aspx/McNeel/MoireEffects.html
Unfortuantely, the simplicity of Revit rendering means that often times you do
not have the fine control over parameters which will eliminate this issue.
Matt
matt@stachoni.com
On Thu, 21 Jan 2010 06:32:44 -0800, ordonezmiguel <> wrote:
>do you know how avoid oscillatory effects brick walls? (see image)
>The animation I made with 100% of raytracing format (2787x1695 pixels) that is supposed to be the maximum, and I selected softshadows, blurry reflections and blurry transparency.
>The type of wall is "masonery/brick/burgundy_12 "running", but I have done with other class of brick and the effect (oscillatory) is the same.
> thanks
>Edited by: ordonezmiguel on Jan 21, 2010 6:32 AM
