Are you talking about the "temp dims" or the permanent dimensions? Temp
dims will stay the same size relative to the screen resolution as you zoom.
Change your screen resolution if they are too small.
Permanent dims are sized according to the scale of the view you are working
in. Change the scale of the view if the dims are too small.
"quattda" wrote in message
news:12480219.1097072212999.JavaMail.jive@jiveforum1.autodesk.com...
> I am new to Revit and am using version 6.1. When I am placing a wall in my
drawing the dimensions are too small to read. When I try to zoom in they
resize and are still too small. I looked in help to try to stop this from
happening. Where do I need to go to change this setting?
