"alot of work"
this time is directly related to the level of detail required for the set,
the level of families available, and how advanced your template is.
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
"cdv" wrote in message
news:5730594@discussion.autodesk.com...
If you model the building correctly then plans, elevations and sections
derived from the model should be correct. You still will have to dimension,
note, and detail them as well as create sheets to place the all of the
views. So there is still alot of work to do but you do not have to redraw
the various plans, elevations and sections.
If you think that once a model is created all you have to do is just hit a
button and construction drawings are automatically created and completed, no
that does not happen.
wrote in message news:5730556@discussion.autodesk.com...
autodesk says the construction documents
are created directly from the model and
if the model is correct then the drawings
are automatically correct..
i don't know what question to begin
with but i am trying to understand this
relationship between the model and the
construction documents..
when i mass a building and put walls and
doors and windows and design its interior
and render the whole thing- HOW does this
"automatically" produce construction
documents?
ANY comments on this please..
