Autodesk Revit 2015 Update Release 4 CAD doesn't work
5 REPLIES 5
mlakins
407 Views, 5 Replies
Updated to the latest service pack (from ur3 to ur4) and am having issues. BOTH Cad and Revit 2015 are crashing even before opening the file. Anybody else experiencing this?
5 REPLIES 5
Alisder.Brown
in reply to: mlakins
mlakins
This happened to me yesterday.
When i click to run the software the "launch" window pops up but then i get the "Application has stopped working" message and it crashes. Every time. Tried a repair, un install/reinstall, system rollback and cant seem to fix it... yet.
I am currently in the process of trying some more in depth methods to fix it so ill keep you posted. Should know by today/tomorrow morning 🙂
Not sure what has caused it though :S
Cheers
Alisder Brown
Senior BIM Coordinator
Scotland, UK
mlakins
in reply to: Alisder.Brown
Yeah, we are having that exact problem too. If you go to control panel, programs and features, view installed updates, and remove the CAD portion of the release 4, it should work. Again, I only removed the cad portion of 4th update and BOTH revit and CAD are functioning okay. Confirm if this works for you.
Alisder.Brown
So nothing seems to fix this issue for me
Done a full clean un-install, removed regkeys and folders, removed absolutely everything to do with Autodesk from the computer, reinstalled at startup.
It seems to be crashing when checking the licence, so i tried DC the internet but same issue, still crashed at same point 😞
Ive removed some o the recent Windows updates, new graphics drivers, removed FlexNET files and nothing seems to work. I know it was working a fortnight ago so i think im going to do a system restore and see if it resolves the issue 😕
Alisder Brown
Scotland, UK
Alisder.Brown
Just an FYI, ive made a new post myself so i could escalate it to Support incase people think im double posting issues
Alisder Brown
Scotland, UK
mlakins
I did a little research and found that there is an error moving from
service pack two to service pack four amongst the autodesk community. I
have no solution on how to fix it. You've done everything I would have. I
hope they can find you a fix! Sorry for your troubles.
Mark Lakins
Architectural Designer
Jenkins Custom Homes
3813 Juniper Trace Suite 100 Austin, Texas 78738
C: *682.554.0331* T: 512.402.9222
visitus at*www.newhousebuilder.com
Two Time Texas Custom Builder of the Year
*Intellectual Property.** The content of this e-mail and all attachments,
including without limitation all drawings, text, images, and other
information, is protected under United States’ and other copyright laws and
is wholly owned by SL Jenkins, LLC. (referred to as Jenkins Custom Homes).
Any information provided to you may not, except under written license, be
copied, reproduced, transmitted, displayed, distributed, altered, stored
for subsequent use, or otherwise used in whole or in part in any manner
without prior written consent of Jenkins Custom Homes, except to the extent
that such use is authorized for the estimating, planning and execution of
the named project. Trademarks, logos, images, and service marks used by
Jenkins Custom Homes are the property of Jenkins Custom Homes, and may not
be used without permission, and then only with proper written consent.*
Rail Community
