Autodesk Revit 2013 Extensions
2 REPLIES 2
1402 Views, 2 Replies
I have installed Student Version of Revit 2013 and the associated Extension pack. Installation and basic operation all OK.
As per the screen shot attached, the Extensions ->Modelling->Wood Framing Walls option exists and works OK.
I was also expecting to see in the Extensions ->Modelling 'Rafter Framing and 'Roof Trusses' options.
Should these have been installed with the Extensions pack? Are they available elsewhere?
Are these only available under 'Subscription' ?
Is this avalable to the Student users?
Many thanks
John
2 REPLIES 2
edwin.prakoso
Hi John,
I'm sorry that I see this thread late.
Those tools are not included in that extension.
You need 'Timber Roof Framing Extensions for Revit 2013' to get rafter framing and roof trusses tools.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
JBerns
in reply to: edwin.prakoso
Will these extensions work with Revit LT 2013?
Can the Wood Framing Extension generate a schedule or Quantity Take-Off?
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
