Revit Architecture
Revit Architecture
0 Kudos
Post 1 of 5
Autodesk 360: Sync Error Persistently Pops Up
706 Views, 4 Replies
11-09-2012 09:25 AM
I've already downloaded the 2013 Service Pack 1 for this problem but I still get the popup message every half hour or so (see attached image). Anyone have a permanent solution?
I only used the service for a render once with Revit Architecture 2013. I'm running Windows 7 64-bit.
*Expert Elite*
652 Kudos
Post 2 of 5
Re: Autodesk 360: Sync Error Persistently Pops Up
11-09-2012 11:10 AM in reply to: QuickTactical
i get this every so often
the easiest way to get rid of that message is to uninstall autodesk sync
*Expert Elite*
62 Kudos
Post 3 of 5
11-11-2012 04:44 AM in reply to: QuickTactical
Try the Autodesk Sync SP1:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20541251&linkID=9240698
(it doesn't mention Revit but it could help)
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Active Contributor
125 Kudos
Post 4 of 5
11-14-2012 03:11 PM in reply to: vladimir.michl
I've had the sync error start to pop again too. All products have been updated/service packed. Been occuring for the past week.
Member
0 Kudos
Post 5 of 5
10-09-2013 08:57 AM in reply to: vladimir.michl
Vlad, did you even read his post? He said SP1 was installed.
I too have persistant sync error in the tray, I too have the latest version of EVERYTHING installed. Very annoying.
Post to the Community
New Post
