Autodesk 360: Sync Error Persistently Pops Up
4 REPLIES 4
859 Views, 4 Replies
I've already downloaded the 2013 Service Pack 1 for this problem but I still get the popup message every half hour or so (see attached image). Anyone have a permanent solution?
I only used the service for a render once with Revit Architecture 2013. I'm running Windows 7 64-bit.
4 REPLIES 4
DarrenP
i get this every so often
the easiest way to get rid of that message is to uninstall autodesk sync
DarrenP
vladimir_michl
Try the Autodesk Sync SP1:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20541251&linkID=9240698
(it doesn't mention Revit but it could help)
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
in reply to: vladimir_michl
I've had the sync error start to pop again too. All products have been updated/service packed. Been occuring for the past week.
Vlad, did you even read his post? He said SP1 was installed.
I too have persistant sync error in the tray, I too have the latest version of EVERYTHING installed. Very annoying.
