Autodesk 2013 Wood Frame Extension Tool
8 REPLIES 8
Message 1 of 9
9022 Views, 8 Replies
Has anyone heard recently, about the status of the long overdue return of the Wood Frame Extension Tool ?
8 REPLIES 8
Message 2 of 9
lanl
Hi Terry,
You can download the "Revit Extensions for Autodesk Revit 2013" on subscription center. Once install this, you will find this tool under Extension tab- -Modeling- -Wood Framing Wall.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
Message 3 of 9
in reply to: lanl
Lei Lan,
Thank you !
Message 4 of 9
nwelch
What is the issue with the wood framing extension tool and the disappointment of not being able to save a simple file of at least the basic setting that would keep you from having to reset every time you pick a different wall. I am using Revit 2013 with this extension and very disappointed in it's lack of ability at least as I'm concerned.
Residential Home Designer
Nathan
Message 5 of 9
When I go to subscription center for Revit 2013 I dont see it for download. Can you post a link?
Message 6 of 9
DarrenP
are you looking under view all available product enhancements?
DarrenP
Message 7 of 9
in reply to: DarrenP
I cant find it either and I have a Subscription. I really want to download it... I go to the roof framing one but it doesn't do walls from what I can tell. Autodesk Reps told me the roof one will do walls.... Can someone please explain
Message 8 of 9
Here is the link for the Revit extension! 🙂
https://students.autodesk.com/?nd=revit_extensions
Message 9 of 9
in reply to: nwelch
