Has anyone heard recently, about the status of the long overdue return of the Wood Frame Extension Tool ?
Solved by lanl. Go to Solution.
Hi Terry,
You can download the "Revit Extensions for Autodesk Revit 2013" on subscription center. Once install this, you will find this tool under Extension tab- -Modeling- -Wood Framing Wall.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
What is the issue with the wood framing extension tool and the disappointment of not being able to save a simple file of at least the basic setting that would keep you from having to reset every time you pick a different wall. I am using Revit 2013 with this extension and very disappointed in it's lack of ability at least as I'm concerned.
Residential Home Designer
Nathan
are you looking under view all available product enhancements?
DarrenP
I cant find it either and I have a Subscription. I really want to download it... I go to the roof framing one but it doesn't do walls from what I can tell. Autodesk Reps told me the roof one will do walls.... Can someone please explain
Did you check out our tool: http://www.strucsoftsolutions.com/products/mwf-homebuilder-suite/
