Autocad To Revit 8
2 REPLIES 2
154 Views, 2 Replies
Autocad To Revit 8
I have an object in AutoCAD 06 that was extruded, Is there an easy way to get that into Revit and Make it a component?
2 REPLIES 2
It will be "dumb" but you can import it into the appropriate family type and then it will be schedulable and you can set its visibility to be off in plan and add symbol lines as needed.
When you import the 3D object be sure your are in the solids command. I
dont think you have to be in the solids command to import but it can make it
cleaner.
wrote in message news:5058706@discussion.autodesk.com...
