With the AutoCAD Revit 2014 I am unable to open DWG file. It gives me a failed to open error. I have attached screen shot below. We did download DWG TruView 2014.
Solved by DarrenP. Go to Solution.
you don't directly open .dwg files in revit only .rvt, .rfa, .adsk,.rte, rft, you can import .dwg into your project
create a new project and go to the insert tab and click on import cad file or you can link the .dwg file into revit by clicking on the mange links button on the insert tab on the ribbon
revit isn't autocad
DarrenP
