I've been doing some looking and can't find anything. It looks like you can't do it but is there a way to convert a 3D .dwg to an .rvt file?
as I know - No!
If you have an AEC object you can export using IFC file into Revit and convert there in revit entity...but for solids,no.
Anyway you can export a .dwg file into Revit and if it is well structured on layers you can assign materials to the imported entity. The imported entity can be also be cut .....but I think that is all you can do....Explosion make it desapear.....
