auto fraction stack
3 REPLIES 3
dcooper
2346 Views, 3 Replies
auto fraction stack
How do you enable stacked fractions for dimensions in Revit 2013?
3 REPLIES 3
AJA14
in reply to: dcooper
Hi. In the type properties of the dimensions, change the units to feet and fractional inches and choose the appropriate rounding. Remember you can also override dimensions if you don't need to create a new type.
If this solves your problem, Please accept as solution.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
dcooper
in reply to: AJA14
I already had that set. That setting does not cause the fraction to stack. Both numerator and denominator are side by side on the same line separated by a "/".
VWD-MLM
Stacked Fractions are not possible in any of the Revit flavors.............It's been asked for as long as I can remember (2007)
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
