Revit Architecture
Valued Mentor
gh_ar
Message 1 of 3 (154 Views)
Attached Wall
154 Views, 2 Replies
09-14-2013 10:08 AM
hi
I wish On Wall Attached Longitudinal Or Trim The  italic Existed.
I mean, this is ,If I have a wall And a Refrenc Plane In italic, If the Trim tool It I modified End Wall With Angle Refrenc
Plane Be adjusted Not perpendicular.
Like the image below
constantin.stroescu
Message 2 of 3 (136 Views)
Re: Attached Wall
09-14-2013 11:17 AM in reply to: gh_ar
In order to Cut the wall after an angle I usualy use one of the two methods described in the following:
  1. Draw a second wall at the desired  angle and then override with Hide Elements -image 1
  2. Make a Component >Model in Place >Wall >Extruded Void and Cut the wall with it. If you attach the edge (as seen in the second image) to the reference plane -then moving the reference plane - moves the cut...image 2 and 3
The first method is a quick one , but it has to be repeated in every View because is an override by View....
Constantin Stroescu
BIM Manager AGD
Valued Mentor
gh_ar
Message 3 of 3 (130 Views)
Re: Attached Wall
09-14-2013 11:47 AM in reply to: gh_ar
Hi
Thanks for your answer.
Yes - I am using the wall of the Void
But In my opinion This is a problem Because for such a small task Should Enter space Families will The own Time is wasted.
And about Hiding:
I think the projects The the output is It is important This method is not correctly.
For many reasons:
-In each View Should chosen to hide.
-Cost estimates will not .
-Potential problems Dealing with other elements There is.
And ....
