hi
I wish On Wall Attached Longitudinal Or Trim The italic Existed.
I mean, this is ,If I have a wall And a Refrenc Plane In italic, If the Trim tool It I modified End Wall With Angle Refrenc
Plane Be adjusted Not perpendicular.
Like the image below
In order to Cut the wall after an angle I usualy use one of the two methods described in the following:
The first method is a quick one , but it has to be repeated in every View because is an override by View....
Constantin Stroescu
Hi
Thanks for your answer.
Yes - I am using the wall of the Void
But In my opinion This is a problem Because for such a small task Should Enter space Families will The own Time is wasted.
And about Hiding:
I think the projects The the output is It is important This method is not correctly.
For many reasons:
-In each View Should chosen to hide.
-Cost estimates will not .
-Potential problems Dealing with other elements There is.
And ....
