Attach wall to stairs
2 REPLIES 2
436 Views, 2 Replies
I'm trying to attach the smaller wall to the underside of the stairs but the wall doesn't cut to the stairs. Is this possible somehow?
Also, is there any easy way to attach a wall to the underside of a circular or spiral stair?
2 REPLIES 2
Some good examples of what you are trying to do at www.augi.com. Do a quick search there and you will get several different options. "pfrederico" wrote in message news:2552802.1110977288550.JavaMail.jive@jiveforum2.autodesk.com... > I'm trying to attach the smaller wall to the underside of the stairs but the wall doesn't cut to the stairs. Is this possible somehow? > > Also, is there any easy way to attach a wall to the underside of a circular or spiral stair?
Miguel Miranda
Create a ref plane aligned with the bottom of the stair and attach the wall to the ref plane.
Miguel Miranda
