Attach Top/Base
4 REPLIES 4
mcam0088
1271 Views, 4 Replies
Attach Top/Base
I am a student of architecture, and have been using Revit Architecture for just under 6 months.  In a recent project of mine, I have a ramp which serves 2 functions;
  1. As a ramp from level 0 to level 1
  2. as a roof
I cannot seem to get Revit to connect the tops of the walls under the ramp to the base (of the ramp).
Any help would be greatly appreciated.
4 REPLIES 4
Can you be more spefic? Why don't you make just a roof and attach the walls to it?
Maybe you have a certain shape that creates you problems...can you make a printscreen and post it ?
Constantin Stroescu
I'm not sure whether I can make a roof to replace the ramp.
Attached are screen shots of the project.
Now I understand you...You want to have the advantage of  the railings so you choose to use Ramp function...
In this case, I suggest  to use a workaround:
  • first make a ramp with railing
  • then, a mass element : In Place Mass
  • and finally wall by face...
as shown in my screen recording:
https://screencast.autodesk.com/Main/Details/74118b5b-91d8-4767-b96d-ae1993e2ef9d
Constantin Stroescu
Thanks for the video, it was very helpful 🙂
