Revit Architecture
Revit Architecture
doni49
Message 1 of 5 (727 Views)
Asphalt Shingles Require "Realistic", B&B Wall Pattern requires "Shaded"
727 Views, 4 Replies
06-07-2013 11:33 AM
I created a Board and Batten material using a pattern I downloaded from this forum (http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Board-Batten-Exterior-Finish/m-p/2514833#M...).
The wall looks great when viewed in "Shaded".  But when viewed in "Realistic", the B&B pattern disappears and is replaced by solid color.
I used the OOTB Asphal Shingles on my roof.  If my view is set to "Shaded", they do not show -- all I get is solid gray.  If I change the view to realistic, I get the roof shingles.
I'm currently at a loss here.  Any ideas?
I'm attaching a screen shot of what the two look like.
Thanks!
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post!
mpwuzhere
Message 2 of 5 (717 Views)
Re: Asphalt Shingles Require "Realistic", B&B Wall Pattern require
06-07-2013 11:55 AM in reply to: doni49
Realistic utilizes an actual image map of what the material looks like....so if you don't have an image assigned it shows as a solid color.  Be aware that any 3D Fill Patterns assigned to a material will not show up in Realistic either.
doni49
Message 3 of 5 (715 Views)
06-07-2013 11:58 AM in reply to: mpwuzhere
Thinking that it might be something along those lines, I downloaded an asphalt shingle pattern file (http://www.revitcity.com/downloads.php?action=view&object_id=3012) and assigned it to the roof as well.  I thought maybe the pattern would show up when in shaded.  But it didn't appear.
Don Ireland
Forum links:
Civil 3D General
mpwuzhere
Message 4 of 5 (707 Views)
06-07-2013 12:26 PM in reply to: doni49
Was it Model or Drafting Pattern?  Drafting Patterns only show in 2D....Model in both 2D and 3D....
doni49
Message 5 of 5 (704 Views)
06-07-2013 12:36 PM in reply to: doni49
Model
Don Ireland
Forum links:
Civil 3D General
