Does anyone know a descent template to create ASKs for Revit? They are fairly easy with the xref capabilities of AutoCAD, but when you try and use templates I have found so far online, they can't be used in conjunction with an existing sheet template. The current template found is transparent and can't really be modififed.
For the most part, we simple issue full-sheet revisions, since isolating a single view to re-issue is kind of a hassle.
If you must issue a single detail, and don't want to go through all the hassle of duplicating views, then hiding the tags, etc., you can create a temporary sheet border to overlay on the permanent sheet long enough to create a record PDF, and then delete the temporary border. Takes a little time to set up the border, but generating multiple ASIs/ASKs is quick and relatively painless.
Here's a longer discussion on the advantages/disadvantages of each method, but the general consensus is that a temporary masking titleblock is the most efficient method.
