ASK architectural sketches
2 REPLIES 2
1322 Views, 2 Replies
Does anyone know a descent template to create ASKs for Revit? They are fairly easy with the xref capabilities of AutoCAD, but when you try and use templates I have found so far online, they can't be used in conjunction with an existing sheet template. The current template found is transparent and can't really be modififed.
Tags (1)
2 REPLIES 2
rosskirby
For the most part, we simple issue full-sheet revisions, since isolating a single view to re-issue is kind of a hassle.
If you must issue a single detail, and don't want to go through all the hassle of duplicating views, then hiding the tags, etc., you can create a temporary sheet border to overlay on the permanent sheet long enough to create a record PDF, and then delete the temporary border.  Takes a little time to set up the border, but generating multiple ASIs/ASKs is quick and relatively painless.
Here's a longer discussion on the advantages/disadvantages of each method, but the general consensus is that a temporary masking titleblock is the most efficient method.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
in reply to: rosskirby
Good Answer! 🙂
