Array of Levels
5 REPLIES 5
dgdg
442 Views, 5 Replies
Array of Levels
In an elevation view I want to create more levels by arraying level two up. What do I need to do so these arrayed levels create the related floor plan levels too? If I draw each level separately in elevation the related floor plan level is created.
5 REPLIES 5
EvgenyK
in reply to: dgdg
You can copy your plan into clipboard, choose from menu Edit>Paste Aligned>Select Levels by name and select target levels you need
in reply to: dgdg
After arraying the level lines, go to View>New>Plan, and pick the Level that
you want to make a new plan for. Repeat for additioanl levels.
wrote in message news:4838845@discussion.autodesk.com...
dgdg
in reply to: dgdg
Thanks!
in reply to: dgdg
No need to repeat all the steps for each Level. Just use Ctrl-select and Shift-select in the list of Levels to create multiple plan
views at the same time.
"Scott Davis" wrote in message news:4839210@discussion.autodesk.com...
in reply to: dgdg
ah yes....i forgot you could do this! thanks Irwin!
"Irwin Jungreis" wrote in message
news:4842404@discussion.autodesk.com...
